Answers posted by -Grimm- on June 26, 2014 at 04:57 PM
Problems at all. If you need to rotate the cam you can do it by turning the crank gently a little bit and then the cam or cams. If you feel them hit, back them off a bit and turn the crank again untill the cams are close to where you need them. Just be very gentle when doing this so you dont bend a valve. I have done this on several occasions with good results.
